1 - 7 of 7 Posts
Hi wondering if some knows how to check to see if my case is getting fuel in the injectors she won`t start. She ran great two weeks ago parked her now she will not start. Any information would be helpful.
Thanks Rick96
Hello wondering if anyone knows about the kill cable for fuel on my early 60`s Case CK 188 diesel. Ran great for years, parked her about a month ago now she will not start. I checked for fuel, fuel going into the pump checked the screen under fuel inlet and it was clean. I cracked the fuel fitting on # 1 injector and no fuel when cranking her over. I think my kill cable is messed up it only attached to a large spring at the front of engine block. I can put the cable to kill the fuel and then pust it in to start, but it is not attached to the pump in any way. (should it be ) If anyone knows about this please reply to my post. Thanks Rick96
I still have no luck with my case 580 ck starting. I pulled the top cover off and all the parts inside move with the kill cable to off and on. I removed the two screws on the timing cover on the pump. I see the line for the timing mark if I look inside with a mirror and someone cranks her over should I see that shaft rotate inside the timing window.
1 - 7 of 7 Posts
