1 - 3 of 3 Posts
What can you tell me about a Case 1190? From what I gather, they are only powered by a 3-cylinder diesel engine that put's 37 hp to the drawbar & 43 hp to the PTO.
Are they a good tractor? Any pro's or con's that you know of? I know it varies by location, but what is the value in good operating condition, with brand new rear tires & only mild cosmetic flaws?
Discussion Starter #2
Isn't anyone familiar with a Case 1190?
Hi PT
The 1190 was one of the better tractors that David Brown - case made, it definately was the best starter, check all is working as it should, their engines had no weaknesses, try all gears, should have syncro on 2nd&3rd in all 4 ranges, if the 3pt lift lifts and holds, 2speed pto, listen when running for chipped pto gears, they are easy to service and repair allthough some repair tasks are unique to DB-Case,if its tidy give it a go.
1 - 3 of 3 Posts
