carb linkage on YTH22v46
1623 Views 0 Replies 1 Participant Last post by  therealex
Hi all,
I removed my carb because it showed the usual signs of fouling - stalled, wouldn't restart, sprayed starter fluid and it ran for a few seconds. Anyway, took it off, cleaned it as much as I could without taking it apart, and put it back on - what I thought was the right now.
Now I'm not so sure. Still doesn't run, and the fuel feed is ok. I would very much appreciate if if someone could confirm I hooked up the linkage on the left side (facing the engine from the front) correctly. I didn't see it moving when I moved the throttle control.
Images: not sure why they're sideways, they aren't on my computer! I even turn them purposely, and they still come up sideways here.
Here's the linkage, close up (sorry, it's a bit fuzzy):
Here's a shot of the engine, you can zoom in and see the linkage there also:
It snaps into that plastic piece, so I'm guessing that's right. But there's a hook at the bottom - does that snap into something that I'm not seeing?
I really appreciate the help. If I did it right, then I guess I'll have to do a carb teardown!
- Russ
1 - 1 of 1 Posts
1 - 1 of 1 Posts
