I came across a old John Deere push mower that wasnt running. Pulled it apart and cleaned everything and over looked the fuel needle that was under the float. The corrosion had locked, blocked the passage way.
I may have made mistake a fatal mistake cleaning the bore the needle goes in. I used a dremel tool with a grinding ball that fit in with room to spare. I didnt use much pressure, just lightly went over it
I didnt go all the way to the orifice the needle points into within the bore.
The float doesnt have spring on it, the needle slides into a extension of the float.
Now gas just pours out.
Could I have made the tolerance between the needle and bore to large or even made the seat for the needle to large? If so how can it be fixed? If the needle is the issue where can I get a replacement? If the tolerance is that big of a issue can I get a larger needle?
