You might be able to make a tool out of small diameter copper tubing or steel brake tubing...have to find a size thats close in diameter inside as the screw head is,and flatten one side of the tube till it'll grab the screw..
On one of my Sears Suburbans,the darn main jet screw is very hard to get too with the air filter housing on it,it obscures it,and I get shocked every time I go to adjust it by the coil's primary "kill" wire!..
I finally decided to try using a hunk of 3/8" I.D. rubber fuel line hose as a tool ,it will force over the knurled screw tightly enough to allow you to use it as an "extention" and adjust it while running much easier...its hard to use a screwdriver to do it,it has to be "perfect" length and will vibrate out of the slot constantly with it running,making adjusting it a real frustrating experience..
