So I have my Craftsman Franken-Tractor that I picked up for free about two weeks ago up and running. It has a 16.5 HP Briggs number 313777-0134-E1.
It had a blown head gasket, a bad magneto and carb issues. I replaced the head gasket, adjusted the valves to .004" (some say .003" others .005", I think you're splitting hairs but .004" shouldn't cause issues), replaced the air filter and spark plug, replaced the magneto and replaced the carburetor with an aftermarket Nikki style one from Amazon. I also adjusted the throttle linkage to factory spec.
Now it starts and runs, but rough. It runs pretty good with the throttle set all the way down, but with the throttle in the fast position, it surges and backfires and eventually will stall. If you move it to the choke position (one lever for choke and throttle) it will run much better but still surges very bad. Then if you drive it up a hill (put a load on it) it seems to stop surging. Turning the mixture screw in or out does virtually nothing.
Not sure if the aftermarket carb is just junk, or if I need to look at something else. Any help would be appreciated.
