1 - 13 of 13 Posts
Hello,
I acquired this piece from a shuttered factory surplus purchase. I know it has a Perkins diesel engine(384 hours). And also a M15 Wilden pump.
It's time to clear the barn and just need to know what I am selling. Any idea what the value could be? Thanks for replies.
value?
Wheel Tire Automotive tire Vehicle Motor vehicle
Light Audio equipment Electronic instrument Automotive lighting Gas
Wood Machine Gas Metal Engineering
Glove Pipeline transport Orange Valve Headgear
· Super Moderator
Hi kklukas
Brown Door mat Rectangle Wood Beige
looks like a mobile pump I found this
Font Circle Rectangle Number Art
...If you google Wilden Pump there is quite a bit of information. With that few hours I think it is worth quite a bit if the engine does in fact work
Looks like a pump, question is just.. how nasty of stuff can you put through it. If you can drain swamps with it its a pretty dang sweet piece of equipment. If it only pumps ‘clean’ liquids its a bit more limited but still worth a pretty penny to the right person.
From only the pics it looks like a double acting diaphragm pump. I think MarkLI got it right. For use in slurry pumping. As a kid, we had a beach well the size of a small room. It would fill up with sand and a local guy had a pumper that would suck sand and water out in a slurry. That one was a vertically arranged double pump. This one appears to be arranged horizontally.
It’s a double acting diaphragm pump used to pump various semi-liquids. They are a trash pump of sorts and able to move a lot of grit without damage to the pump itself. We use them extensively at the *** to move seepage and oil, but also used them at the last powerhouse I worked to move lime slurry in the slaker building to the boiler house.
I guess I am confused but those two things don't go together??
That pump is an air powered diaphragm pump as posted above. The Perkins Diesel engine is some kind of hydraulic power unit. So that engine and hydraulic pump can't run that compressed air diaphragm pump?
Here is the pump:
M15 Air Powered Pump
1 - 13 of 13 Posts
