I have an x700 along with a Kolpin Dirt Works 3pt hitch. I like the fact that the hitch can be removed when not needed.
I currently use it on my 425 and it has an electric actuator to work it. Just a little lacking in power.
I have an idea to replace the electric actuator with a hydraulic cylinder and use the lower ports on the Hyd couplers and lower lever on dash to operate it when I need to drag driveway or move my trailer from behind the shed to the driveway.
One of the big reasons I went with the Kolpin instead of adding a 3pt hitch to the 425 is the option to run both rear 3pt and front blade with angle. since the rear 3pt was electric.
During snow season is when I will want to run both the front blade and 3pt hitch. Is there a way to do this? I am even willing to add a 3rd hydraulic lever to operate it.
Thanks for all the input.
