How does one go about removing the air vane/adjustment collar/throttle shaft/throttle blade from a plastic F series carb? I had need of a governor spring from a donor plastic carb to fit to a metal Walbro and I ended up breaking the central shaft to get the spring out.
As my grandpa used to say "there's gotta be a way to take it apart - it didn't grow together". But I'm stumped. The plastic carbs don't have the screw on top to remove the air vane. One more reason to dislike those hateful things.
Thanks for allowing me to tap the MTF knowledge base.
Charlie
Charlie
