Went out, put the key in and it fired right up. Drove it out of the shed and the engine slowly died. Hmmm - turned the key and it started again but it blew black smoke (probably from choking a warm engine) and slowly died again. :banghead3
Pushed it back into the shed and turned it over but no go. Pulled the plug and it was dry! Turned the key and a nice spark. Fuel filter plugged I hope but fuel pump could be the culprit. It acted like it was out of gas. I used a small solid fuel filter which I'm hoping is plugged.
If a new filter isn't the problem can I take the gas line off at the carb and see if the pump is working? In other words turn it over and see if gas comes out? Is there another way to test a pump? Thanks
