BTW, for what it’s worth—I’m glad you all have the free time and willingness to help out people like me who know next to nothing about this stuff!
3. Reassemble axle housing. (Replace gasket/seal while doing this?)
On the L there may be shims under the axle housing where it joins the trans. Carefully clean and reinstall those, but don't add any more gaskets or anything. If there's a gasket when you disassemble, mic it and install one same thickness.
The two axle housings are custom fitted to each unit, to center and set the preload on the big tapered rollers that hold the axle. You want to keep that clearance undisturbed.
I really appreciate everybody’s help. I learn so much here.
Some have 2, the older models. From memory .Is there just the one hole in the end of the rod?
Correct to above, red info added.1. Drain the oil
2. Remove left side axle housing and inspect and clean out oil pick up screen. Plus check for loose hardware.
4. Connect compressor at 15 PSI as shown above, and ensure crank is in correct position. 15 psi or less, you have sludge in the crankpin which you do not want to stir up.
5. Apply air and watch for oil to exit rod hole.
6. Reconnect oil line and fill back up with oil.
Regarding the sludge, what can/should be done to remedy that?
Follow this process. I use rtv on shims/gasket and have no oil leaks.On the L there may be shims under the axle housing where it joins the trans. Carefully clean and reinstall those, but don't add any more gaskets or anything. If there's a gasket when you disassemble, mic it and install one same thickness.
You can also cut groves the length of the threads on a bolt and use it as a chaser. Just don't forget to lube the hole well so the bolt doesn't stick.
Nonetheless, I imagine that after a quick hone of the cylinder I should be able to stick with a new standard size piston?
Those actually look really good! I wouldn't touch 'em, just clean 'em and button it up.Attached are some pics of the valves and seats.
There's a spec, but that's even tougher to measure accurately.Out of curiosity, generally speaking how does one know when the valve guides need replaced? I assume mine are fine, but thought I’d ask.
