First, I think that is one of the worse schematics I have ever seen, can't read much of anything.
I think the lift motor is causing a fault code to be set in one of the modules killing the power.
Removing the fuse lets the fault code to be reset, which restores power.
Since the schematic is for a machine with a manual deck lift, where the lift switch/motor is tied into the harness is not shown.
There is also a chance you have a connection that is making contact, but just barely.
The load from the deck lift motor is to much for the connection and it loses power.
That said, a bad connection is not likely to reset by removing and reinstalling the main fuse, so I have about talked myself out of that option while typing my response.
