Last week a seal failed at 18 hours and all the hydraulic fluid ended up in my driveway - I spent 4 hours last Monday at the dealer waiting to get that fixed.
Yesterday, at 29 hours, I turned the ignition switch off - and the tractor kept running. The Temp and Fuel Gage's drop down and the Tach goes off as if it shut down, but the engine keeps running. The safety kills don't work (they did before this happened). If I engage the PTO, and step out of the seat, the PTO remains engaged and the MMM continues to run. The HST forward and reverse will engage if I'm out of the seat.
I shut it down by putting the HST in high, setting the parking brake, and stalling it. I've started it twice since but the the same situation recurs.
A fellow from Australia (OTT forum - thank you kubseki) was kind enough to direct me to Dave's Aug 2010 post on shutting down using the fuel injector cut-off (http://www.mytractorforum.com/showthread.php?t=144843), and I see that this issue may be about a 20 Amp fuse. Tomorrow I'm going to try hooking up a wire to the fuel injector pump shut down.
I was considering putting the BX back onto the trailer on Monday and driving the 50 miles back to the dealer and losing another day from work. But since reading Dave's post, if I can get the shut-off to work, I may just call the dealer and have them come out to fix it.
I'm beginning to wonder if this thing came off the assembly line on a Friday afternoon.
