1 - 1 of 1 Posts
Discussion Starter #1 (Edited by Moderator)
Hi all! I wanted a Gannon earthcavator but none were available near me so I decided to try building my own, and here is how I did it.
I started the build using an old IH Cub push blade, but any heavy duty blade will work. The moldboard is 48" X 10" X X .25". To this was welded end plates 16"L X 12"H X .25"T
The roll over collars/bearings are made from heavy wall tubing wall T= .25" the OD = 2.25" ID = 1.75" L = 1.0625". These were welded to the end plated centered 6" up / down and 4" from the aft end of the plate.
The hitch arms are fabricated from flat stock 2" X .5" X 16". The axle shaft is a solid shaft 1.75" OD 1.125" L which was welded to the end of the arm. The hitch is made using 2" X 50" pipe welded to 2" X 2" .25" angle iron that's 52" L.
The 3 PT lift tabs are welded to the 2" angle iron along with the top link mast. The top link mast is 14" H from the 2" flat stock angle cut to give it approx a 2" forward tilt. This hitch is designed for Cat 0 mounting, and all holes are 5/8".
The roll over latch assembly: Arms, the 2" material should be 13.5" long tapered at the aft end to allow them it move up over the locking tabs. A 1.0625" notch was cut into the arm at 14.5" from the tapered ends 1.0625" deep the forward ends were drilled .75" for the connecting axle.
A .75" round shaft 54" L is supported with 4 supports [email protected] 2" X 4" material and [email protected] 1.5" X .25" X 4" flat stock. These are welded to the top of the 3 pt 2" angle.
The locking tabs are fabricated from bar stock 1" X .5" X 2.25" L. 6 are needed and welded to each end plate. The process I used was to have the blade assembly attached to the tractor 3 pt. and raised up with the lock arms in place, then held with a C clamp. I placed the lock tab on the arm notches and tack welded it in place and then welded them solid.
The rippers I ordered from Ag Supply : http://mower-blades.agrisupply.com/search#w=box blade shank&asug=box blade
P/N 86634 they are .75" X 2" X 16". I only wanted them 6" long so 10" was cut off but I did use the upper drilled ends cut to2.25" to make mounts for the rippers. The ripper mount is angle iron 3" X 3" X 3/8" X 48". This was welded to the back of the moldboard and the end plated and 4 ripper mounts were welded to the 3" angle spaced for 4 teeth.
I wanted to be able to remove the 3 pt hitch from the blade so the hitch arms are bolted to the hitch which why the 2" pipe is 50" and the 2" angle is 52". A "nut", so to speak, was fabricated from the 2" material 2" X 2" drilled and tapped with1/2" #20 fine thread then welded to the 2" angle, and the 2" pipe for the hitch arms are drilled 1/2" and bolted to the hitch assy with 1/2 fine thread grade 8 bolts with lock washers. The cutting edges are .25" X 5 " X 48" bolted to the blade with 5 bolts.
Another view of the ripper mount attachment
The roll over release lever is made from 1.25" X .25" X 30" bar stock bolted to the latching axle assembly.
The roll over latch arms again, which, as noted above, are 13.5" length.
Also I did not use a one piece latch release axle as you can see in the above photo as it also had to be dissembled to remove the hitch. I used some 1" X 1" square tubing as a connector and which drilled 3/16" and an aircraft AN 3 bolt was used.
As you see it in the above picture I also installed a spring on the release lever to pull it to the locked position.
1 - 1 of 1 Posts
