1 - 2 of 2 Posts
I want to build a grader box, similar to a DR Grader, but to pull behind my Ford NAA. Instead of raising and lowering it electrically, I will use the tractor's hydraulics. I've got an old busted up flail mower, that I'm going to make the frame out of. Any suggestions on what to use for scarifiers would be appreciated.
Jesus Saves
I built my box blade and used factory scarifier teeth that I found at Agri-Supply for about $6 each. They are notched so they can be raised or lowered manually for whatever the need may be. Mine is a 5 foot box that I used a piece of 1/2" thick 30" pipe for the moldboard with 1/2" steel plate on the sides. The front bar and frame are built from 1/2" thick 4X4 steel tubing that I found in the scrap yard. The entire box weighs about 350 pounds.
1 - 2 of 2 Posts
