1 - 7 of 7 Posts
Can a X700 series tractor have a bucket loader on the front? Or does one need a CUT for that? If that is the case what is the min tractor for a bucket and small back hoe?
John Deere sells a front end loader for the X700 series. I'm pretty sure that it will fit all except the 4 wheel steer model(s). There is no backhoe available for the X700's though.
The smallest current model from JD that can take a front end loader and a backhoe is the 2305, which some call a CUT, and others call a SCUT (sub-compact utility tractor). You can get one new with both already mounted for around $16,000.00 to $17,000.00 not including sales tax. There's a SCUT from Cub Cadet that's about the same size and cost for the same setup. Kubota makes one in that price range as well, their's might be a thousand more. I'm sure that there's other brands too.
Just look at my avatar its a X485 with a 45loader which would be a X720 with a 45loader. Yes it take's the JD OEM 45loader.
Loader's for X700 series
O.E.M. http://www.deere.com/en_US/ProductC...achment?attNmbr=3990M&prodNmbr=SKU21819&tM=HO
Aftermarket Loaders.
http://or-bilt.com/OR-BILT_49_Loader.html
http://ironmanfabrication.net/index.html
http://www.kwmanufacturing.com/
Slip Buckets
O.E.M. http://www.deere.com/en_US/ProductC...hment?attNmbr=LP54000&prodNmbr=SKU21819&tM=HO
Aftermarket
http://johnnyproducts.com/J_Bucket_HTMs/JBpage_Sr_John_Deere_300-400.htm
Hope this gives you some Idea about a loader or Slip Bucket for the X700 series We even have a member here that modified a 45loader to fit his X729 or X749 which is AWS and 4WD. The Kwick-way backhoe for the older 425 thru 455 can be modified to fit the X700 series or older X400 and X500 series. :thThumbsU
Thanks for all the info, if i was to buy X700 series it would be the 4WD version.
USMC
I think it's the X728 and up for 4WD. slkpk
AKA Moses Lawnagan
If you can swing the $$$, get the 748. The diesel is Sa-Weet!
JD RULES
Hi KeithB78 , :ditto: to KHodges !!!
If you don't want to go with a current series and went used , there are alot
of other capable Machines out there ...
Later,x595
1 - 7 of 7 Posts
