1 - 6 of 6 Posts
I have a John Deere 755 tractor with bucket. The bucket control handle is on the right side of the driver seat. It controls raising and lowering the bucket as well as turning the bucket to dump or not dump. My problem - the handle where it connects with 2 vertical "bars" is supposed to have a bolt (or pin) go through so that when you pull the handle toward you the bucket turns up and if you push the handle away from you the bucket dumps. Well, somehow this bolt/pin "disappeared". It happened during a snow cleanup some months ago - I am not sure how. What I did was feed some electrical wire to connect the handle with the 2 vertical "bars". The problem I have is - how do I put a bolt/pin in there? The space is so tight it is all I can do to feed a wire to hold things together. It feels like I may have to take the seat off to get enough space to work.
I will get pictures but hoping someone has dealt with this before?
A pic would help greatly.
1 - 6 of 6 Posts
