1 - 20 of 25 Posts
Well, after several weeks of research and scouring craigslist, I brought home my first John Deere (that I've personally owned)! Found a 1980 210, very good shape, same owner for the last 14 years, for $450. It's all manual, and came with a 42" blade in great shape, cast iron wheel weights in great shape, and chains. It did NOT come with a deck, unfortunately, as it was COMPLETELY stripped & rusted out...the PO said it was ugly when he got the tractor, but he used it for several years, then when it was too torn up to use, he stripped it, set it next to his garage, then bought his 318 and used the 210 for plowing. Still, I've already got a lead on a guy with a couple 39" decks that he says are all in good, servicable condition, so I'm gonna go check those out and hopefully get a deck for another $150.
The tractor appears to be well cared for; newer tires with good tread, new drive belts (both of them), new plug & wire, relatively new Duralast Gold battery, new seat, and new steering wheel. It is missing the grille emblem (what's that theory about the grille emblem on a used JD? Hahaha), and it has a somewhat interesting mix of faded paint and repainted areas. I asked him about the repainting while I was looking at it, he said he started just doing touch-up spots, with the goal of repainting the whole thing, but never got to that point. Oh well, the aesthetics don't bother me. The PO added auxillary headlights (wired into the lighting switch), and they are quite bright, so those should be nice for plowing in the dark or finishing up mowing if it gets late; along with the headlights, he also added a light strip along the rear, but I'm pretty indifferent about those.
It fired right up, ran great (I did notice 1 or 2 small puffs of smoke when I quickly accelerated the throttle, so I realize that means the engine has some wear, but no other smoking or signs of engine issues), I drove it around a good bit, tested every gear, utilized the variator (works great on the low-end, the high-end notches don't adjust the speed much, so it might need some adjustment), ran it at different throttle speeds, all checked out great. The blade raises, lowers, pivots, and angles as expected (no remote angle kit, but oh well, maybe I'll find one). We pulled the right side engine cover off and I verified that all PTO parts are there and operate as expected, and the PTO-to-deck belt pulleys are in place and spin freely. The PTO-to-deck belt tensioner handle is broken off of the front (like all used tractors with these tensioners it seems), but that's replacable. Overall, I think I got a very solid 210 with the accessories I wanted for a good price.
PO said he change the oil a few weeks ago, but I'll still change the oil and transaxle fluid, along with greasing the zerk fittings, giving it a good cleaning, check out the variator and see if I need to adjust it...anything else I should address?
Sorry for the book, I'm a detailed guy...Couple pics attached, right after I picked it up and just about to take it home (not taken at the seller's place, it plowed a much smaller driveway and a sidewalk).
Looks like a great tractor at a very good price. Beware..it does become addictive...lol
Discussion Starter · #8 ·
Thanks guys! I appreciate all the comments.
Nice looking 212. You'lle enjoy the added lights as the OEM lights are certainly lacking. Don't be ambigious about the lights on the back, if you have a busy road that your working on at night those may be lifesavers!
That is a good point. I wasn't really thinking about it, but yeah, those will increase my visibility when I'm plowing the sidewalk along the road.
· THE TRACTOR HUNTER
Same owner for the last 14 years and he didn't even have a deck for it? It looks like a nice little 210 though.
· MTF & OCC Poster
A nice little 210 for sure. Hope you're successful with picking up a mower deck!
· USMC
Great looking tractor and have fun with it. slkpk
Just wait until you push a wall of snow off the edge of your driveway with that thing. Then you'll understand why we all love our 200's! Good luck with her. I love the camo paint job too, a stealth Deere!
It's a looker, good job in getting it . Nice that you wont have to do very much to it changing fluids and filters like you said . The way that blade sits on the trailer I d wonder how much steel has been worn off the moldboard , it would appear that the blade edge and its bolts have been worn away ? I hope I m wrong .
Discussion Starter · #17 ·
Thanks again for the comments and compliments!
Well, he did have a deck, but it rotted out and he picked up a 318 to mow with...supposedly that was several years ago. Naturally, there's no records, but I had no reason to doubt him.
I'm looking forward to finding out how much snow this thing will push :thThumbsU
Thanks. Yeah, it's very nice that I'll do the normal maintenance and then I should be good to go! By moldboard, I'm assuming you're referring to the cutting edge that is bolted to the bottom edge of the plow? The cutting edge is pretty worn down, but all bolts/nuts are present; the bottoms of some of the nuts/carriage bolts are worn down, but as best I can tell, the bottom of the blade itself is intact. I see what you're saying by looking at the pic, but I think it's just because the blade wasn't sitting evenly on the already uneven deck of my trailer, haha. Regardless, thanks for pointing it out, I hadn't thought about the cutting edge specifically, other than noticing that it's rather worn.
I'd say I definitely need a new cutting edge and will probably replace the bolts/nuts also; any suggestions on the best place to look for a replacement cutting edge?
Good lookin tractor. And yes this site and GREEN is addicting. I think you'll find as I have this is the best tractor forum on the web thanks to its members.
Get a deck and you have a 4 season machine. looks good and a fair price
I wish my blade was in that Good of shape. I have a lot of work ahead of me...
1 - 20 of 25 Posts
