I got a free non-running STX38 yellow deck on the weekend. I have briefly looked it over. The first thing I had to fix was the left steering spindle. Over the years it had worn so bad that it was sitting at a angle and seized.
Now that the steering works I moved onto getting it running.
I put a battery in and tried cranking it over. The key is broken off in the ignition but with a screw driver it can be turned. It didn't crank overly fast and then the starter struggled to turn it over and stopped. The starter was groaning. No gas in it at all, but I sprayed some brake cleaner into the carb and it wouldn't even fire.
There is oil in it but I am wondering if someone ran it too hard and the crank bearings or rod might be seizing.
The good:
Free
Hood has no cracks
The Bad:
Had to fix the front axle where the left spindle goes through so it would steer.
Rear tire won't hold air.
Hard to turn over (maybe starter, maybe cooked engine)...
Won't start.
Can't push it on the ground. Seems like it is stuck in gear when it says it is in neutral.
Powder coat is toast.
Seat is trashed.
I don't really want to put any money into this until I know it will at least run.
The good:
Free
Hood has no cracks
The Bad:
Won't start.
Seat is trashed.
