PA318, you hit the target dead center. $1000 total for both. I may end up selling the snow blower since I already have a plow and it doesn't snow that much here in cincinnati.
i was able to successfully hook up the snow blower. i read in the manual that instead of buying a new scraper piece, you can simply unbolt it and rotate it 180 degrees for a new scraper. problem is, I can't get the nuts off the bolts. Its like they are small carriage bolts, and the holes are no longer square.
every time i turn the nut, the entire bolt turns. any ideas?
was unsuccessful at installing the tiller. need to run to lowes tomorrow and pick up some small hardware. i will (hopefully) know tomorrow if my cylinder can lift the thing or not.
edit: oh, and when the snowblower is running at full throttle, the entire mower shakes. is that normal, or do I need to investigate the gears and chain?
