I have a 2008 Troy built Bronco. It is making a noise and jumping as if the gears were striped in the transmission. It started a while back, I can't remember exactly when I first noticed it, but It's geting worse to the point that it will hardly go anymore. When it first started it would only do it when going up hills, now it doies it on level ground also. So far I have replaced the drive belts, (the one was very bad), I've also had the transaxle apart and replaced the drive shaft and gears and shimed some excess freeplay, I've replaced the input pinion. I've also replaced the varible pully assembly. The only thing I haven't replaced yet is the differential unit, It appeared O.K. when I had the transaxle apart. I don't know where to go next. Can anyone help me??? Any assistance would be greatly appreciated. Lynn Brown.
:banghead3
:banghead3
