Maybe there is a better place to post this question, but I'll try here first....I notice very little activity on the ZTR front mount forum......
I have a ztr with a Briggs and Stratton Vanguard Model 261777 Type 001601
Today, it started right up, but then quickly dies....I immediately thought fuel....so I checked the level and even changed the filter.
It will crank over and cough through the carb...
I pulled the flywheel to makes sure the key had not sheared....it was OK. I pulled the valve cover and everything appears to be ok - no loose valve stems, etc....everything seemed to work fine when I cranked it over.....
It's got good consistent spark.....
Any ideas what's wrong? I can't find much info on this engine.....is there an electronic module, etc??
Thanks........I can't believe it went from running fine to dead in 2 seconds....:thSick:
I don't have a compression tester.....
