1 - 2 of 2 Posts
So, I go to start YT3000 for the first time this year. She fired right up but only ran for a few seconds and then ran out of gas. I pulled the pump and tried huffing and puffing on the impulse line and it seemed like it should work. After I cleaned it up a bit I noticed some sort of breather screen on the back side of it. Not sure why it's there and if having it plugged with dirt had a detrimental effect on it.
Anyway, I put the pump back on and gave her another go and she fired right up. I popped the cowl also to look for mouse nests and found only a small stash of seeds. Checked the oil in the hydro as well.
Meanwhile, it's snowing outside but I'll be good to go for next weekend to mow.
Certified Technician
One of 2 things happened.
Fuel bowl wasnt full, some gas had evaporated since it was last run, and took a second to pump more fuel in...
Anti-deisel solenoid was stuck.
1 - 2 of 2 Posts
