About a year or so ago I re-powered my tractor with a good ole 1985 Briggs & Stratton 16hp opposed twin. It's worked great until recently when it began to start slower & slower. The battery I was using had come with the tractor and I have no idea of its age. Combine that with fact I use it to power my 3pt hitch winch so I figured replacing the battery was a good place to start. After replacing the battery the staring was better, but still not "good". I've done quite a bit of testing & checking of the electrical system and I've narrowed it down to the starter. I've rebuilt starters before, new brushes & a good cleaning will bring most of them back. Before I go out and spend 20 bucks on a brush kit I have another 12v starter from a 2000 something Briggs & Stratton v-twin. If you take a look at the pictures below you will clearly see that the mounting brackets are different, but if you look closer you will see that the body, starter gear look very similar. Has anyone every tried to interchange the internals on these starters?
Starter in my opposed twin:
Starter from a v-twin:
