Craftsman 24 HP Intek 2-cylinder, Model 4455677 Type 0827 E1, Code 0708 10YG. About 570 accumulated operating hours.
Started barely running-- took to independent shop. Said "bent" pushrods. Replaced them. Ran for less than an hour and same problem. He repaired it again. Ran for about 5 hours and same problem--but worse. So I now know that this fellow needs some help.
Researched the problem on YouTube and with Google. Google found this forum.
Mention of Walt Conner having developed a fix involving machining. Could not find details-- none of the links or email addresses worked.
Now am convinced that the problem is loose valve guide(s).
Could someone please direct me to details of the fix devised by Mr. Conner and any other durable repairs of which you are aware?
Has Briggs made effective changes to the newest replacement cylinder heads?
Your help is very much appreciated.
