No way the valves could come preadjusted. The intake push rod is aluminum. The exhaust is steel.valve adjustment must be done as per manual. Bit tedious but straight forward.
I just checked it again, it appears to be on the upper limit, and there IS a slight angle leaning away from the dipstick, so maybe a little much, but it's VERY clean, like new looking, no blackness at all to it, I changed the oil and filter last October and I've been running it at that level for months with no problem. And no fuel I can see or smell in the oil, even in the oil that came out of the rod chamber when I took the head off. But even if it was slightly overfilled, wouldn't that wet the plug with oil, and not have just a clean plug that smells like gas and dying out with white smoke?Have you checked the oil in that engine? Possible it's contaminated with fuel and over full.
Mike
Yes, you can see by the pic that the one I took that still had the "gunk" buildup looked a little different over by the chamber, but on the other picture once I cleaned the gunk off the gasket looked great. Maybe the gunk buildup in the other areas was allowing a bit through that other area?Do you inspect the head gasket for damage in area about centre of the pushrod galley .had you noticed any oil in the air filter housing? Your smoke is typical of a blown head gasket. Common on those engines.
No, every where I've looked, about the only place I see it is the B & S site, and they want money for it...I was a Helo maintenance guy in the Army for 20 years, and I still have some of my maintenance references, so I was thinking about looking up what's known as "standard torque" for those type bolts, unless you know where I can find the toque and the pattern....Actually 140 is high. It is hard to get accurate readings because of the compression release .gasket damage commonly on the cylinder side. Do you have the repair manual for proper head bolt torquing and valve adjustment?
Had to pull the flywheel to access and remove the breather cover underneath. Did torque to 100 ft lbs or best I could, hard to hold the flywheel but it's probably close.you mention putting the flywheel on. Not sure why you would have removed it for the smoking issue. What did you torque the flywheel nut to? A 31 engine spec is 100 ft lbs. Did you R&R the magnetron coil as well? Just another thought on the original problem. If you put the new carb on without draining and refilling with fresh oil you may have still been getting a gas/oil mixture past the rings to produce the smoke. And they may be some in the muffler to burn off. Hopefully new carb is not flooding unless there was a lot of crap in your fuel supply line.
:drunkie: I'm calling this one mission complete! So yesterday when cleaning up I did spot a part (see pic) which was a miracle because I have an aggregate driveway, and spotting anything small like this, especially on an oil soaked area, is almost impossible. So I was smart enough to keep it and took the pic.Check the flywheel key. If it sheared then flywheel is shifted a bit but everything still turns but the spark timing will be off. 100 ft lbs is a lot of torque. I use the cotton rope in the cylinder trick for tightening those.
