I have a Briggs 8hp (190702 date code 75) with no spark that came on a Snapper I bought a couple of years ago. It has not run since I have had it so today I got it out to see if I could figure out what was wrong. I have disconnected kill wire, changed plugs, set coil air gap at .012, changed points and condenser and set gap at .020. Is there a way to check this coil with a volt ohm meter? If so how. The flywheel key looks good.
Cannon
Cannon
