Hi and Happy New Year to all. A friend was given and old log splitter that did not run. He said that it had sat for ten years with no use. He took it to a local dealer with a good repair shop to see if they could make it run. After two weeks, he called them and they said that the engine was shot and needed replaced. I told him to bring it to me and I would take a look at it. To the dealers credit they did not charge him since they made no repairs and if he decided on a new engine, let them know. Well the engine is 1980 5 HP Briggs and all it needed was some TLC. The intake valve was froze open. So, did I the following and that puppy runs sweet and solid. Freed and polished the valve stem, cleaned the carb.and gas tank, replaced rotted muffler. Had no spark at this point, so took flywheel off and set the points gap as well as the coil gap. Also found that the flywheel key had a small twist so it was replaced. Put back together and it started on the second pull. Cleaned the gas cap vent, adjusted the carb. and it runs GREAT. Other then the key, three gaskets and a new muffler, no parts were needed. I just love to keep the old stuff working and feel bad that we have become such a throw away world. Take care, Time
