Strange, just had one come in running on 1 lung, 125psi on one side, 30 on the other. I pulled the valve cover and the intake push rod was sitting loose. no damage, rocker was fine, lash adjuster was tight, rocker mount was tight..I snapped the push rod back under the rocker and set the lash on all 4 rockers, just to be sure, and also inspected all 4 guides for wear or moving...found nothing.
Cranked right up..runs fine, I ran it wide open about 45 minutes, no problems...about 150 hours on it.
Makes you wonder if it was ever installed at the factory...
