I just completed a repair to this engine after it bent a push rod, which i really appreciate Walt's advice on the fix, but now that's it's all together now it wont rev to 3500 rpms. I dont have a tac so i'm guessing it's only reaching about 2500 rpms. Everything seems to be connected as the manual states and this problem did not exist prior to tear down. I've adjusted the static governor settings but problem hasnt changed. When WOT at about 2500 rpms i can manually open the throttle to get it to rev to 3500rpms so it seems like theres too much resistance on the governor that's preventing it to rev'in to the desired rpms.
Is there any chance i put the internals back together wrong? The governor shaft has a "paddle" on the end of it that sits on the back of a spool that may have gotten installed in the spool instead of behind it? I was very careful not to let that happen but i'm grasping at straws here. Would this cause the engine not to respond to the governor correctly??
