Nice machine greybeard..
Whats that thing behind your kbeitz
Ingersall44 you wouldnt have any idea where i could find some parts for it
I appreciate the pics , maybe i could an get some men asurements in the future and fab something
A few things... the shaft attaches to those holes in the frame half way between the trans, and the axle. the chain goes from the trans, to the big sprocket on the center shaft. The rear chain goes from the small on the center, to the axle sprocket. The little tube that sicks up on the shaft in the picture is threaded, and holds a bolt, and a lock nut, that adjusts the shaft down. As for the chain... I don't know the number of links off hand, but know at least one will need a half link. Ill try to find more info. Its a balance to get both chains tight from the same adjustment. IMHO the one bugaboo in a great tractor. Odd are if you find used the small sprockets will be toast from slipping chain links. I had someone weld on new sprockets.
Also the little plate inboard of the mount plate, but outboard of the little adjustment tube.... you will not need that. That's for the tractors that have the brake on the rear axle. the brake rods pivit on it. Yours has the brake on the trans output. Im not sure how that was hooked up. All mine have the rear brake.
