1 - 7 of 7 Posts
· Super Moderator
· Super Moderator
Ken he's got a X300 lawn tractor. Not the older prior to 1992 300 series tractor which is shown in your link. He would need a sleeve hitch to use that boxscrape. :thThumbsU
Edit: :duh: :00000060:
Hi
I don't think the x300 is rated for ground engaging equipment like the box blade. It would be pretty hard on the transmission.
Brian
The X300 is not rated for ground engaging equipment. The closest you can get is a plug aerator. If you did try to pull a box scraper you would need some serious rear wieght or you will loose traction quickly due to the turf tires and light duty transmission. I wouldn't recommand this because you'll be seriously over working the K46.
1 - 7 of 7 Posts
