1 - 3 of 3 Posts
Hi All,
Bought a MT372 last weekend. 4 Hour drive to pick it up in Pennsylvania but I hope well worth the effort. Paid 850.00, it runs well, only issue that I can see so far is the brakes seem to be dragging. I'm hoping this is a fairly simple fix and I would welcome input from any owners that have faced this issue.
Creter
Discussion Starter #2
Would anyone have suggestions as to what would cause the brake to squeal? They also seem to stick, that is the peddle does not spring back on it own. any tips would be appreciated.
Creter
Sorry I missed the original post.
I suspect you need to adjust your brake linkage and do some lubricating.
If that does not help, then you are going to need to check your drum or disc pads. Not positive which ones your tractor will have as my I&T does not reference above MT300.
850 is a steal!
Sent from my SM-N950W using Tapatalk
1 - 3 of 3 Posts
