1 - 15 of 15 Posts
Gravely1964
So last summer I had worked on a gentlemen's Pro 8 at work. Found out he lived up the road ( 10 miles away perhaps). And he had some older stuff he wanted to get rid of. Exchanged numbers when he got the stuff out he would call. Fast forward a week ago gave me a call that he was gonna sell it all. Him and his wife are moveing down to WV to be closer to his daughter. And anything not gotten rid of would go threw an auction.
Made an offer, he countered and we came to an agreement on $600 for everything. I knew the pro was a good solid tractor. Then the fun part loading it. Trailer winch is a life saver!
It was dusk when I set out for home
Truck bed full
Trailer load
Pro 8 runs decent
Old style exhaust on the 52, but its locked up
Flat belt pto
V belt pto
Quick hitch parts
United farm tools 40 inch deck. Only one spindle spins ugh
Not enough pic room for the next stage of fun. Getting them out back and unloaded. Truck is still full yet as its to wet to move around
Gravely1964
Discussion Starter #2
Serial numbers C10A
59 LI
87 pro 8
52 L
So my plan to get the load out back was the 8163-T project and its 2 inch trailer ball. Went well till the turf tires pun here
When in doubt call the 818-T, chained up and weighed down, will sound like a plane and push like a train
Made it outa that jam and promptly ran outa gas here
Unloading things
New style deck note gear head. Missing skid shoes
Everything in the shop
Trying to figure out how to get the stuff off the truck out back. Thinking another trailer trip, with the 450 perhaps. It has chains is plan a, but hate putting alot weight to the lift hitchs. For next time ........
Another nice grab Steve!
I'd love to find a UFT deck like that for my 88E :)
Gravely1964
And I'd love to have a utf myself to put this on once its fixed....
First thing I decided to tackle was the utf deck.
With the covers off I see why its locked up for sure
Yepppppppp
Dug all that out to find one broken belt and rusted threw spring. Unstuck spindle pretty quick and hit them with grease to force the water out.
Pull gear head off to heat, beat, repeat to get idler arms moveing. All that is working just need one belt to try it
Gear head is massive and heavy!
Started trying to unstick the 52 L. Pulled head, no broken head bolts. But found this with no spark plug, not surprised
Bore looks ok, but stuck in worst spot all the way down
Put some oil in and will try again another day. To break it free
Surprise in the air hose. Not alive ,but you rotten little boogers
Nice bunch of stuff. Can't read the pic - does the Pro-8 say 6 or 8 lead? Swifty or no?
Gravely1964
Long time no hear John.
Its a 6 lead, no swifty. Which is ok by me. On pc should be able to click on pic and make them bigger. Just finally got the truck unloaded this morning. i'll post those pics in a second here.
Gravely1964
Will try full images here, see if better or worse.
Finally dry enough to get Big Red into the back yard and back out. Do believe I have every size of rotary plow blades here
Rotary plows, cultivators, and push cultivator too
More stuff
More stuff
Deck with lead weight
All mower parts
Yanny making this all easy priceless
Going to go out now and see if the c10A will run. I put jump box to starter and turned over last night any how
Been busy redoing the house but hoping to get back to more Gravely fun eventually. Ah, no Swifty so that makes more sense. Should be a good mowing machine?
Gravely1964
Discussion Starter #9
One more parts pic of both belt drive setups
Started into the c10A, bolted up deck. Realized chains hit deck. Take them off before driveing far. Installed a battery from work junk pile.
While doing that had trans oil draining. And added fresh
After cleaning the points it ran well but with fuel on gas leaked outa bowel vent.
Never seen this before!
So pulled car bowel, needle sealed by pushing up float. Float good and adjust float level.
After that were in the yard and trucking. Deck isn't to noisy either on just one spindle. I'll grab a belt from work today :D
52 still stuck every time I go by I play with it. Switched to pb blaster now
Gravely1964
Discussion Starter #11
Nice haul, plenty of toys. Will be difficult to choose between which one to use.....LOL
Keep switching penetrants & use ATF, time and patience required.
RB in RI
Yup that my theory. I may flip the fan shroud up and heat the cylinder up if need be later on. Go out tonight and see what it does. And try putting the other belt on the 884 deck
Gravely1964
Discussion Starter #12
Ok first off, took the head off the 59 to inspect bore and see if the 52 L was the stuck the whole way down. Found out it was 2 inches up in the stroke.
So I let it sit, ran a hone threw up top, with a pipe wrench on crank pulley, pulling of best got a little captain in me bit. Left foot pushing down, hammer and chisel in hands gave her a few wraps. She broke loose. At first only moveing up and down alittle. Then about a full turn with the bottom of the bore ok. Ran hone threw again and again till it would spin the whole way around.
Knowing how ugly it would be sure it would have stuck rings. I then pulled cylider. which was still an adventure to get off the piston. Used deep well sockets on stud to space it up and pull it donw out. Has a deep rust pits where the rings were. Did run a hone threw it and cleaned it up alot. But forgot to take a pic
Boy them sure are some stuck rings
alright a break threw on belt saga. there not 1/2 inch belts. i know right
There 3/8th belts. 38 will work. But would recommend a 37 inch belt on these
All back together
Pro 8 and C10A hanging out
Onto the L's
Gravely1964
Discussion Starter #13
So decided to put the new style deck on the Pro 8. Only issue found was no skid shoes. Added set from junk deck skin
Serial numbers
Old style with retrofit kit, vs new
Model tag on brush hog
Retro fit
The correct hardware
Good home made studs
Expertly cataloged with the other one I'll never use
and new style brush hog on. Now if only it wasn't raining to try it out. Also was going to put the ma 106 on the 59 Li. But found attachment holes are striped in advanced casting. Ugh So I'll get running and see if it worth switching the advanced casting or not
Gravely1964
Discussion Starter #14
So starting into the 59 LI
First off drained water oil mix from trans. Rust was outa gas tank I was letting drain here
Gas tank had water in it. Thankfully fuel shut off was off. So removed shut off and let drain
Then got it running with normal points cleaning and adding oil and oil filter. No need for a carb cleaning. But 3 outa 4 attachment mounting holes were stripped in the advanced casting. Ran it just enough to check function. Great oil pressure
So pulled that advanced casting off
Inspected forward clutch cone, looks good
Another 6 bolt advanced casting on
3 outa 4 successes. Number 4 maybe turning into abit of a challenge. More on that in another post later on
Awesome :D on a side note the run flats really do suck, even with chains
I'll throw up my vids of working on and useing things here in the next post. I don't think I've done the 59 vid yet
Gravely1964
Discussion Starter #15
1 - 15 of 15 Posts
