The title says it; I'm thinking a brush or landscape rake on a rear boom, for raking up debris after cutting my big hedge.
The hedge is about 350 meters long; some of it I have to clean both sides, so about 500 meters of cut brush once a month.
Some of it is level, some is a semi-ditch at a 30 degree angle.
I had the idea to have the rake fold up with a hydraulic cylinder [like a backhoe bucket] to clamp the cuttings against some sort of cage structure, then I could lift the boom with the 3-point and drop the cuttings as desired.
The boom would lift 8 feet or so [4X the 3-point arm movement] to drop into a trailer or direct on a burn pile.
Not the perfect solution, but fairly easy to build I think.
Has anyone see anything similar? It seems a bit obvious but I didn't find anything like it in my searches.
