Was thinking what blades I could get to update the cut, I need a higher lift blade to get the grass out from under the deck faster. After looking at whats out there for Bolens, it was a pretty lame selection compared to modern blades.
Then it came to me, "how do you drill a hole in a drill bit"? (hardened steel blades), water jet it. There is a shop down the street that does water jetting so I am going to see if they can not only cut a blade to length, but drill the holes too.
Then I can pick out any modern blade and adapt it.
What is everyone else doing?
