On my 1966 bolens with a Kohler QT17 I've got a hard job setting the throttle, it's either screaming wide open or idling. I've only got to move the lever maybe 1/4" up and it's one or the other.
Idealy, I'd like the full throw of the lever to be usable from idle to 3600.
I've got the governor set correctly, I loosened the governor arm and pushed the arm away from the carb while turning the shaft clockwise. The cable is in the top hole of the arm on the carb with the spring on the next hole down going to the 5th hole out on the governor arm. Anyone got any ideas?......Mike
