1 - 3 of 3 Posts
got the cadet going. was mowing great, then it just quit. when i tried to start it, gasoline came out of one side of the muffler. whats going on ?
thanks in advance
The float or needle valve in the carb may be stuck. You may want to provide more info, on what model of tractor and engine brand and type.
In addition to that excellent advise, also make sure the needle valve gasket is okay and in place. I had one split on me recently that wasn't that old. It ended up causing the engine to run horrible since it was getting way too much gas into the carburetor bowl.
1 - 3 of 3 Posts
