Welcome aboard Birchw1.
Since it continues to blow the fuse even when the pto isn't engaged I suspect a wire has gotten pinched either by the mowers linkage and/or near where the belt(s) route.
You said you went over it pretty good but sometimes I've found that I can stare at something for hrs and not see the obvious problem, only to walk away, take a break and come back later and see it plain as day
Is the pto manual or electric?
Another thought would be related to it sitting alot. Connectors/connections can corrode over time and grounds can be lost as well as circuits openning up.
You'd probably do well to get some electronic contact cleaner, open up all of the connectors one at a time while giving them a good shower. Then remove any grounds clean up the connector/connection then reattach.
Good luck
Good luck
