1 - 9 of 9 Posts
Hello Everyone.
I'm using the Blitz Black paint from John Deere and wondered if any of you
use a primer under it? The information on the can leads you to believe it
does not need a primer.
Thanks,
Tim, Ohio
Three of my friends
If the black u rr spraying over is in good condition you can spray any Jd paint over it with good results
I have used Blitz Black both with and without primer. Both work equally well. The key is to properly clean the surface to be painted. Another advantage of Blitz Black is that it is easy to touch up if you get a scratch.
1 - 9 of 9 Posts
