I hit a stump with my JD Z track 335e. The cap on spindle was badly damaged. I was concerned that the spindle could have been bent so replaced that spindle assembly and the other at the spindle at the same time. I put on other older JD blades (not ones used when hit stump) but the blades are still hitting about every 30 sec. I jack up the mower and get under deck and spin it but cannot really tell. Two questions: 1. Did not replace the bolt and washer that hold on the blade. they look fine but maybe they are slight bent and whould get replaced? 2. Nothing in the manual but on this machine do the blades need to be at exact perpendicular 90?
Thanks
Thanks
