does anybody know on a 54 " deck what the stock blade clearance is between the blades ???...I had damaged the tip of mine (on the discharge chute side)..so I thought this would be a good time to try gator blades...they are they same length as the stock blades but the center blade and left side blade just clip each other when mowing.....the right side blade nad center miss each other by about 1/4 ".....while left side and center about 1/16"......?
all spindles seem tight no play or noise when spinning no wobble can be seen........before I drop deck tomorrow and try standard blades, any ideas ?????
(I really like the Gator's cut...cept for that "tick" tick")
