need new blades for this tractor. cant find anywhere what size the deck is. blades are broke but it looks like they are 18 3/4 or maybe 19" long. hole is 3/4 width is 2". what size deck? 37" or 38" where is the best place to get blades . can i get them at TSC?
First need to identify the deck. Here are the 37" side discharge decks listed for the 211-4
1987, 1988 and 1989 35-37SL01 replaced by 35-37SL02
Both decks use Toro blades 109918 replaced by 109079 blade kit Hole 3/4in. round 18.75in. 18-3/4" long.
Others [Napa 2 of # 7-04724] [Oregon 2 of # 91-817]
You can get to the parts lists here
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
The 37" decks have the left spindle further ahead than the right. Let us know if this does not sound correct.
Garry
A semi-retired senior cit
This is where I get most of my blades from. The blades are made by Oregon outdoor equipment, the OEM replacement blade are made of the same material as their Gator mulching blades. I`ve used them and they are good blades, edges last a long time. Here is the link to the Oregon part# 91-817 at mowparts.com. Price each is $9.53, I`ve never had a problem with anything ordered from them.
http://www.mowpart.com/Blades-Wheel...-Compatibility)-<br>(Click-/product_info.html
well you guys are right on. the left spindle is ahead of the right. 37" deck. have blades ordered thanks a bunch.
