the snapper walk behind i just picked up
(seen here http://www.mytractorforum.com/showthread.php?t=143712)
started just spinning the blade like it was loose, i put it on how i found it, 2 thick metal washers then the blade 2 leather type washers, then there's 2 cupped ones on the bolt, no prob,
today, fixed ign. issue, took the motor off thought i had a oil leak, blah,blah, a tiny bit over full no leak,
remount blade& it wants to unscrew while running,
just to check, i took bolt only&it threads into the crank firmly no play, no stripped anything.
what should i replace?all the washers&the adapter?
That was an incessant problem on that vintage Snapper. I believe there was a later style blade hub to replace all the steel and fibre washers.
ok, i'll phone a few local places&see what they have, hardest thing to find would be a deflector so i can switch from bagging
