On my Avery R, I have found the plugs to check the lower rear end oil, but I want to drain them both and add new oil to it. What I call the lower rear end is the section that houses the gears which turn the rear wheels, and protrude down under the rear end attatched to the wheel and are rounded off at the bottom. I have thought about buying some kind of syphon to suck the old oil out. Any and all help is appreciated. Thanks.
Roy
Roy
