1 - 2 of 2 Posts
Trying to find one of the metal braces that holds the mower deck rack on. Looks like a rectangular block about 2" wide by 1" tall by 3" long welded to a flat bar about 7 inches long, at a 90 degree angle, with holes drilled in flat bar.
Block end goes into a square loop on frame and flat bar attaches to mower deck rack.
Have asked local machine/welding shops if they could make it, was told to try and buy one first, would be cheaper. I may end up going to metal supply shop and buying stock metals to weld up one on my own. I prefer using stock parts when available.
I am also interested in buying attachments for the PK. Has manual lift but doesn't have PTO. Guessing it might use cat 0 attachments.
Currently sanding off the JD green paint and getting it prepped for a coat of red. I am not sure of what decals it came with (if any).
Discussion Starter #2
Bracket is no longer needed. Machine would mill one for $150, muffler shop made one for $12 from welded stock.
1 - 2 of 2 Posts
