· Super Moderator
Well, i went yesterday to one of our tower sites to cut the grass. teh lot is T shaped with the office on teh smaller lot (75x150) and the tower on teh big lot(175x300). i cut the small lot no problem. made the first pass around teh big lot and then started teh second pass. about 1/2 way around i felt a twist in teh mower and i thought "it ain't never torqued like that before?!?". at teh 3/4 way mark i happened to notice that both front tires are almost touching the hood on top and splayed out big time at ground level, yep BROKE THE FRONT AXLE AGAIN!:thSick:
it happened the first time around the 250 hours mark, the 2nd right at the 500 hour mark.
there was a thread a few weeks ago asking was the replacement axle any better than the original and i have to say obviously not!:banghead3 :banghead3 :banghead3
i really have been torn between using the X500 for these sites since it is faster. now i have no choice as i really don't have the money to buy a new axle until i cut a couple more times! i am glad that i took teh L130 yesterday, i was going to take teh X500 btu changed my mind. if i had taken it the next cutting for the L would have been 100 miles from home. at least yesterday i was only 45 minutes from home so the trip back to finish ain't bad.
Really sorry to hear about your luck with the L130. Having read most of your posts in the last couple of years I know that you have really pushed your L to its limits and beyond, but you have provided a real service to us here by pointing out its strengths and weaknesses, mostly weaknesses. I know the X500 is much better suited to what you do and will I'm sure last quite a bit longer. Just wanted to say thanks for all the help you have given us, even us background lurkers.
steve
· Super Moderator
yeah it has seen it's fair share of work. i can honestly say that most of the parts i hav ehad to replace over the years were cheap in price. never had a major cost repair done to it.
as far as teh axle breaking 2x, the L130 was sold with a 2 year warranty and the first break was in year 3. i also feel that teh combination of a very rough lawn in part of my yard and the fact this machine has probably ridden 60,000+ miles on a trailer have a lot to do with it. the front end jsut can't take the shock/jarring. i strap it on 4 corners, but it gets jarred pretty good since you can't drive a country road without hitting potholes.
i will fix it, the axle ain't that much, my stepdad jsut bought a lot adjacent to his parents' old house and if nothing else it should last him just fine cutting those 2 smooth properties.
ETA: Deere sold this machine for cutting lots up to 2.5 acres. i honestly have to say that i feel if that is all you do with it then it will last years. i have put close to 500 hours on mine over the last 5 years(6 seasons) and for much of that time i used it to cut up to 10 acres most every week! i figure between that and my using it for ground engaging work pulling a disc and cultivator i prematurely aged it by a good 5-10 years. For typical suburbanites wanting to cut their grass, the L/LA/100 series machiens are fine. pricey for what they do, but jsut fine and will last as long as anything else in their class. for folks who work a machine, stay away from them or expect constant repairs like i have/had.
