I have two MTD's doing the same thing. The belt or the Variable part of the Transmission is slipping.
Both have new belts. The slip in Low gears when I start up a hill or try to operate in the low gears with a load.
If I run the throttle up and shift up to Hi, it'l take off slowly.
One is a 13AM675G062 (yard man) and the other is a 13A747G062 (don't know)
The Yard man still mows, but the other is just a Handy andy to pull stuff with etc.
Maybe there is a "test and adjustments" sequence to fix this problem?
Or maybe my Pully is not moving up n' down on the sliding shaft.
Anybody have anything to help me with in the way of knowledge.
