I think I can help with the drive belt problem. After four belts and two visits from Sears repair we found the solution. I burned up the first belt at the end of last season. I put a new belt on this spring and probably didn’t go 20 feet until the stupid belt dropped off the transaxle pulley and jammed again. I at least didn’t destroy this belt and I went to all the trouble to reinstall the belt, only to have it jam again. CRAP!!!
Threw up my hands and called Sears repair. He came out, checked out all the pulleys, installed a new belt and drove it around the house once. Looking good. Two days later I go out to cut the quickly growing grass and was able to cut half the yard before the @#%*& belt jammed again. When the Sears guy left he told me I had a 30 day warranty so I called them again. He arrived a few days later, raised up the lawn mower and pondered a bit. He again checked every drive pulley for alignment and made sure the tension pulley spring was working OK. I made some suggestions, one being it looked like there was too much room UNDER the pulley and that was letting the belt drop below the pulley.
He called a fellow repairman for some help. Here was his solution, which has worked (KNOCK ON WOOD) thru 5 cuttings of almost two acres each time. If you look at the transaxle you will see a bracket that sits below the drive pulley. It has two wings bent up around the pulley on each side. The solution was to carefully bend the bracket up closer to the pulley and belt. Make sure it doesn’t rub either the belt or pulley. He used a pair of channel locks to bend the bracket. NOTE: It is easier to get to the transaxle if you remove the deck. He drove it around the yard for almost 20 minutes, going from forward to reverse many time (made me cringe several times how rough he was). It is still working.
Give it a try and let us know.
May God Bless,
Danny
