Alright guys,
Please forgive a rookie and possbily stupid questions.
I am going to try to get two suburbans I got running. First set of questions is basic engine questions, forgive me as the extent of engine work I have done is replacing spark plugs and cables/oil.
1. I am planning on draining the oil and gasoline and replacing it. Any further suggestions before I try to turn over?
2. From what I have read, there are ways to check the starter to see if it is working with a multimeter, I feel comfortable reading up on that from previous threads. The next step would be to check spark and compression correct? Would the cheap spark checker and compression tester from harbor freight work? Please bear in mind I am on a small budget.
Next is paint questions
3. What do you recommend for sanding? I have an orbital sander that I could use, but I was considering buying the small sandblaster (again at harbor freight)
http://www.harborfreight.com/portable-abrasive-blaster-kit-37025.html is the one I was looking at. I was thinking of buying that and media from Tractor Supply. I dont have a large compressor, so I was thinking of trying out that small one with my pancake compressor (not expecting to be able to do large areas at a time of course)
4. Paint codes. Anyone know where I can find them or at least a close match? I checked vintagesearsgardentractors.com but couldnt quite find it.
5. Paint application, would I be fine spray painting (can)? Not trying to do a full restoration so not that picky, and my compressor cant handle the nice guns, just want it to look presentable.
6. Decals. Where can I find the decals? May sand around them if they are hard to find, may take them off if it is bad. Any other suggestions welcome and appreciated!
